trapy745
#1 Posted : Thursday, September 4, 2014 3:21:44 PM(UTC)
trapy745
my whirlpool ice maker auger continues to rotate and does not allow water to enter this cycle continues constantly i checked water tube no problem i ran a elect. check with the wire jump on the ice maker and it does initiate the water flow but auger continues to cycle through any help would be appreceated
t.t.
#2 Posted : Friday, September 5, 2014 3:32:21 AM(UTC)
A model number may help others help you.
Find your model number - AppliancePartsPros.com
I am not sure what part you are calling the auger.
Is it the auger in the ice bin that pushes ice out the door?
Is it the ejector/fingers that push the ice cubes out of the ice maker tray?
Sounds like there is a probelm in the ice maker itself.
Usually the easiest fix is to replace the ice maker.
They can be a pain to fix.
