Hi, I have a GE profile which has a problem of not cooling in the Refrigerator section. I did lot of analysis and still have the same problem.
1. Checked the board - No issues. 2. Replaced Defrost Thermostat on the freezer side. 3. Replaced one of the fan on the refrigerator section. Looked like everything was working fine and now I have the same problem of not cooling in the refrigerator and the coil in the refrigerator section is getting frozen. 4. Checked the fan again it is running fine but the refrigerator is not cooling but freezing at the bottom below the fan area where the pointed aluminium coils are located. 5. Please suggest answer step by step.
NP.
