Hurricane
#1 Posted : Thursday, September 4, 2014 10:41:37 AM(UTC)
Hurricane
My Maytag Dryer wont turn on but the interior light works. Ive removed the back panel and noticed the red wire from the timer to the temp switch is burnt out. Ive cut the burnt piece off, striped the wire down and put new terminal connectors on but still no luck...any idea on wether or not ill have to replace the timer or temp switch or both? and should i make a new wire to replace the old or would stripping it and new terminals work? Thanks
#2 Posted : Friday, September 5, 2014 2:50:54 AM(UTC)
A model number may help others help you.
Find your model number - AppliancePartsPros.com
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
canifixit14
#3 Posted : Friday, September 5, 2014 8:33:35 AM(UTC)
canifixit14
If the dryer got too hot it is possible that the thermal fuse blew. Not knowing your model number I cannot tell you where yours is located but I would say near the vent on the back. At least that's where mine was. If you have a meter to check the fuse great. If not you can bypass it and if dryer starts replace the fuse.
