neto1235
#1 Posted : 10 years ago
neto1235
My Samsung gas dryer DV330AGW/XAA stop working. It turns on, when the start button is pressed, it makes a humming sound, then a click but the drum do not turns. I removed the top cover and the drum will turn if it is pushed by hand, then it will continue on its own and all be fine. Checked the belt, ok; replaced the thermostat, still not turning; replaced the thermister, still not turning; replaced the PCB (main board), still not turning. I'm wondering if the belt cut-off switch might be the problem or if any one else has a better sugestion. I'll greatly appreciate any help I can get. Thank you in advance.
#2 Posted : 10 years ago
Parts for Samsung DV330AGW/XAA / Dryer - AppliancePartsPros.com
I am assuming that when you hear the click the motor shuts off. This is the motor's internal thermal protect tripping as the motor is overheating.
Since the drum turns fairly easily by hand it sounds like you need a new motor.
I doubt it is the belt switch. if it was not being held closed by the belt the unit would never run.
Do you get heat when the motor is just buzzing?
Do you get heat when you manually start the unit?
The reason this is important is that the motor has two centrifugal switches on it. They close when the motor gets close to operating speed.
On of them switches in the heater. This ensures that the heater does not come on until there is air flow.
The other switches out the motor's start winding. If left in circuit this would overheat the motor.
So if there is heat when the motor buzzes it could be a problem with the mechanism that activates the switches re: they are always activated so the start winding is not in circuit. Could be just lint etc. May also need a motor replacement.
Do not let it run very long when it is buzzing. as if there is heat it will blow a thermal fuse.
If there is no heat when it buzzes but there is heat when you manually start it then I would replace the motor.
I am off to the lake later today so will not be available till next week.
neto1235
#3 Posted : 10 years ago
neto1235
The motor start with a manual push and continue turning and everything else works fine; drying and heat settings all work as it suppose to. It just that the motor will not start spining the drum on its own. Thanks for replying and advise.
pingu
#4 Posted : 10 years ago
pingu
That your motor starts if the drum / belt is pushed manually it might be the starting capacitor needs replacement. You can google "dryer motor starting capacitor" and see some detailed links about that.
