gerry d
#1 Posted : Monday, August 25, 2014 8:08:36 AM(UTC)
gerry d
Hello,
Last week the dishwasher would not run. It has front panel lights and I am able to change cycles, but it wont run.
I found some computer reset procedure on how to reboot the comp and run diagnostics. That worked and the machine worked well for about 6 loads.
Now I have the same symptoms but the reset does not work. When I push the buttons on the front all the lights lite up after 5 pushes and then the cycle normal light stays on and nothing else happens.
Help.
Gerry
gerry d
#2 Posted : Monday, August 25, 2014 11:23:09 AM(UTC)
gerry d
fixed it. Looks like the input power to the control board connector worked loose and arced and damaged the the board. I cleaned it up and resoldered the pins back to the traces and it is running again.
Gerry
