I purchased used Kenmore Elite Dual Fuel 40" slide in range. Have had it 4 years and love it. BUT nothing gets done when it should. Checked large oven and it runs 25 degrees lower than what I set it for. Everything else seems to work just fine.
Is this thermostat or sensor? I'm on fixed income, live rural area (costs $125 just to get repair man to look at it)......and I need to replace it myself.
Appreciate any information you can give me.:confused:
A model number may help others help you. Find your model number - AppliancePartsPros.comMost units will let you calibrate the oven plus or minus 35 degrees F. The procedure should be in your operators manual. Perhaps this is all it needs. |
THIS FORUM IS DEAD!!!!!!! |
