PeterHoyt
#1 Posted : Sunday, August 24, 2014 4:58:03 PM(UTC)
PeterHoyt
Model Number: mbf2254hew
Brand: Maytag
Age: 1-5 years
Hi and thanks for having this great forum.
My Maytag refrigerator (mbf2254hew) is the bottom freezer type, not double door.
When we open the door, the top control board starts buzzing fairly loudly, and the freezer and temperature LED displays are out.
If we close the door, or just push on the door switch, the control board stops buzzing, and the refrigerator seems to keep working fine.
Another symptom, I can unplug the refrigerator, and then plug it back in, and the control board (usually) acts like it is perfectly okay. But after opening and closing the door a few times, it starts buzzing and the LED displays go out again. A couple times, just by wiggling and pushing on the door switch, the control board will "recover" and the LED displays come back. I can still adjust the temperatures, when the LEDs are working, but after they go out, they reset to "4".
The control boards are available (but a little pricey). Does this sound like a control board gone/going bad? I should mention there was a power outage the night before this started happening.
Thanks!
Pete
#2 Posted : Monday, August 25, 2014 12:53:49 AM(UTC)
Parts for Maytag MBF2254HEW Refrigerator - AppliancePartsPros.com
Yes it does sound like a control board problem.
If you purchase it from AppliancePartsPros they will let you return it if it does not solve the problem.
Please see their return policy.
