jlprsmith@live.com
#1 Posted : Thursday, August 21, 2014 4:16:55 PM(UTC)
jlprsmith@live.com
I have replaced the thermal fuse. I have replaced the cycling thermostat and today I replaced the high limit thermostat. I still have the same problem. The dryer comes on and runs about 10 to 20 minutes, then cut off. I have cleaned the dryer inside and out. There is no lint in the whole dryer. The exhaust hose is clear and no obstructions. I don't know what else to do. Help. Thanks for all your help.:confused: :)
fairbank56
#2 Posted : Thursday, August 21, 2014 5:51:32 PM(UTC)
fairbank56
Groups: Expert
You will need to monitor the voltage to determine whats going on when it shuts off. First, monitor voltage at thermal fuse to ground. Should be 120vac with dryer running. When it shuts off, if voltage drops significantly then could be faulty timer. Monitor voltage at timer BK terminal. If voltage remains steady there but drops at thermal fuse, then timer is bad. You have the wiring diagram, if you get the gist of what I'm saying, then it should be no problem figuring it out. If your not losing voltage at thermal fuse, then you need to check out the neutral circuit which includes door switch and motor switch. Check connections at motor connector. Check for lint buildup inside motor. Could be overheating and tripping motor thermal overload. May also be failing connection at power cord terminal block.
Eric
