dwcountry01
#1 Posted : Wednesday, August 20, 2014 6:53:13 PM(UTC)
dwcountry01
I have a Roper model RS25AWXAL00 and it has worked great for many years until yesterday. The freezer is fine stays at -2 degrees. The fridge is hovering at around 50 degrees but no air is blowing out of vents. I checked the defrost system as per the instructions on this site and everything seems to be working properly. I emptied the unit and let it sit for nearly 24 hours with the doors open and a fan blowing to dry it out. I thought maybe ice was built up in the ducts but obviously that wasn't it. What am I missing? Which fan blows air through the refrigerator section? Any help would be greatly appreciated. Thanks in advance.
David
#2 Posted : Thursday, August 21, 2014 12:48:27 PM(UTC)
You will have to locate the fridg section air return vent, might have an ice jam in it.
