AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Whirlpool Cabrio Dryer won't get hot enough to dry clothes
Good Afternoon,
So I recently replaced the ignitor on the gas dryer. When putting the dryer back together, I ran the test cycle to make sure I have heat. It came out full blast with no problems. When I put clothes in to dry, the dryer runs for ever and never really gets the clothes dry. The temp coming out the exhaust isn't that hot as well. I checked on all of the sensors in the back of the dryer for continuity and they all came back fine. I pressed my finger on the moisture sensor (while running through the tests) and it buzzed back which indicated that was fine. I guess I have hit a brick wall and not sure where to go with it. Any suggestions??
Any help you all can provide is greatly appreciated. Have a great day!
Dryer Repair
