D W M
#1 Posted : Tuesday, August 19, 2014 7:37:31 AM(UTC)
D W M
inside back wall of the dryer. As the clothes dry in automatic that sensor adjust the time accordingly. Check to make sure that those strips are clean and that there is no "debri" on them. If they are clean then you are probably into a thermostat.
Yes but the picture you show is the sensor bar
I,m looking for the wire connections points
There are 4 on sensor 2 on each side, 4 in total
I need to know where the 2 connections (blue and green)
Model MDE9606AZW Maytag drier
fairbank56
#2 Posted : Tuesday, August 19, 2014 9:41:12 AM(UTC)
fairbank56
Groups: Expert
Blue wire connects to one of the bars, green wire to the other, doesn't matter which way. Other two terminals remain unconnected. They should be bent over to prevent bars from separating from mount.
Eric
Where connect the 2 wires to the 4 connections on sensor bar (Dryer Repair)
by D W M 8/19/2014 7:43:07 AM(UTC)
