kellymeg
#1 Posted : Monday, August 18, 2014 8:46:52 AM(UTC)
kellymeg
Freezer and Fridge temps spot on.
Water pressure good. New water filter in place.
Water from door, but no water to icemaker.
Defrosted unit completely, very few drips. No ice plugs.
Replaced triple solenoid valve, ensured no blockages in tubing.
Tested new water valve with multimeter, it's operative.
Swapped the solenoid plugs for dispenser/icemaker... no water to icemaker, now no water to dispenser. Swapped plugs back. Water resumes from door.
Does this mean my wiring harness is damaged, or is it as simple as a new icemaker unit... or am I missing something else? I am so *NOT* an appliance repair person.. just a gal trying to fix something around the house :)
Also, does the icemaker 'call' for the valve to release water on demand, or does water stay in the tube and the icemaker 'release' water as needed? There is currently no water in the icemaker tubing.
If you got this far, thank you for reading :) I look forward to your suggestions :)
Kelly
kellymeg
#2 Posted : Monday, August 18, 2014 5:30:44 PM(UTC)
kellymeg
84 views and not one reply, can no one help me at all? Really at a loss here.
Guest (4)
