Sailandfly
#1 Posted : Friday, August 15, 2014 6:26:36 AM(UTC)
Sailandfly
Jet engine sound on spin cycle for years but lately it is much louder. Can I replace the rear bearing and lip seal without having to replace the entire outer tub assembly($500) ? Maytag says no. A non maytag parts guy on internet says he sells the bearings/seal kits for $80. Not sure if I should attempt that route...any thoughts on non authorized parts....any other suggestions besides buy a new washer?!
Thanks in advance.
sidfink43
#2 Posted : Friday, August 15, 2014 5:25:33 PM(UTC)
sidfink43
The non authorized parts is not a problem, but doing the work correctly is. This is a hard job for anyone who has not done it a number of times.
Sorry, but buying a new one is the recommended solution to this problem on front loaders.
Sailandfly
#3 Posted : Saturday, August 16, 2014 6:20:12 AM(UTC)
Sailandfly
I bought a new washer this morning. Thank you for your response.
Guest (7)
