davidcito989
#1 Posted : Thursday, April 16, 2009 2:30:07 PM(UTC)
davidcito989
I am trying to remove the SGSCV36GB cooktop so I can replace the potentiometers. Can some one give me step by step instructions on how to do this. I can't get the venturi off. I have used PB Blaster to loosen them, but they are are still tight and I think I might be missing something.
pclark
#2 Posted : Thursday, April 16, 2009 5:46:53 PM(UTC)
pclark
Same problem I have with same cooktop. Cant figure out how to access under cooktop lid . Brass nut would be tough to reconnect according to schematics.
nolateam
#3 Posted : Wednesday, June 10, 2009 11:03:24 AM(UTC)
nolateam
Is the venturi ring the hexogonal center of the burner?
I too am looking for a way into the tin can.
jfralin@mac.com
#4 Posted : Monday, August 4, 2014 7:13:57 AM(UTC)
jfralin@mac.com
Same problem here, and yet another post... maybe someone will have a tip.
It sounds so easy, but as I posted before, my venturi bolts are stuck pretty tight. So tight I was using a large Easy Out to turn the thing. This worked - BUT - I only broke the small cast iron bracket beneath the cook top, the nut below is just turning with the venturi.
Does anyone know of an avenue I might pursue to find a way of holding the nut still? I'm loath to call any lo[/B]cal tech; I'm afraid they won't have enough working knowledge of Thermador, only to make a house call and tell me there's nothing they can do.
Read more: http://forum.appliancepartspros...mador.html#ixzz39R7Qt3Yu
http://forum.appliancepartspros.com [/I][/I]
PoorMan1965
#5 Posted : Thursday, September 4, 2014 9:12:42 PM(UTC)
PoorMan1965
Same thing here I have SGCV36 trying to get to downdrft controls
scottthefixitguy
#6 Posted : Sunday, January 29, 2017 1:25:40 PM(UTC)
scottthefixitguy
Those are tricky to get off.
This video shows several ways to get them off
https://youtu.be/M2RpVF6QYtk
HELP: Remove Thermador cooktop (SGVC36G01) top access (Oven Repair (including Ranges and Cooktops))
by jrbarlow22 2/6/2021 7:55:49 AM(UTC)
