Here are your parts includes a wiring diagram.
Parts for Maytag MSD2756GES Refrigerator - AppliancePartsPros.com[COLOR="Blue"]2. The evaporator fan spins fine (I observed it running).[/COLOR]
Is it pushing lots of air?
[COLOR="Blue"]3. I checked the air flow coming out of the upper damper with the freezer door open and closed. The output was the same.[/COLOR]
Something is wrong here.
You should get more air flow into the fresh food side with it open.
Freezer door must be shut.
[COLOR="Blue"]
6. I cleaned what I could get at from the back side of the unit. No change.[/COLOR]
Looks like the unit uses a jelly roll condenser. They are a pain to clean.
If they look fairly dust free they should be OK.
A small mirror and a flashlight should help you check them.
I do not think this is part of your current problem.
The only way I have found to clean them properly is to blow them clean with compressed air but dust gets everywhere.
[COLOR="Blue"]So, I think I ruled out a bad ADC board, bad evaporator fan, and bad defrost heater[/COLOR]
I agree with you
There are two anomalies:
[COLOR="Blue"]A. The strip on the very front between the freezer and fridge compartments is warm to the touch. I don't know what could be hot there.[/COLOR]
Just warm is OK.
This will prevent condensation.
If it gets too warm/hot it is an indication that there is a problem removing the heat from the condenser coils.
This could be a bad condenser/compressor fan, dirty condenser coils or the fan blade or dirty vents on the rear cover plate or kick plate.
[COLOR="Blue"]B. There was a very small bit of ice around the port in the fridge that feeds from the freezer into the meat/cheese drawer. I cleaned it off and poked my finger into the hole. Couldn't feel any further ice.[/COLOR]
You have to make sure that the vent between the two compartments on the side wall is clear on both sides.
The unit does not use a thermistor.
It uses a thermostat (Item 3 in section 02) for the main temperature control.
Also has a thermostat(item 8 in section 02) for the damper door control.
Note that if you click on a part's description/picture a new page will open with additional info on that part, often there is a Q&A section which may help you.
Sounds like the damper flap is not opening re: no change in air flow.
I am not sure what is going on here as everything you list looks OK except the air flow into the fresh food side but you said that the flap was opening so I am a bit lost.
It would not hurt to check the freezer temperature. It should be between 0 and 5 degrees F.
Perhaps the following manual will help you.
You will have to join the site and be logged in to be able to download it.
http://appliancejunk.com...e&id=40;t=1406885225
