Karenbob
#1 Posted : Tuesday, July 29, 2014 6:20:42 PM(UTC)
Karenbob
My kitchen aid is cycling on and off. It beeps or chirps and turns on and off about every 10-30 seconds. The control panel in the fridge flashes on and off each time. Everything at this point is remaining cold. There is a humming noise for most of the time that comes on when the cycling is happening. I've opened the freezer and it sounds like it is centered at the top portion of the freezer. Could
it be the evaporator fan motor. If it is that do you locate it from the back of the fridge or from the inside of the freezer?
If it's something like the condenser fan motor , where is the access to that?
Thank you in advance
