Got a message F1 and keeps on beeping. Bake and broil is not working. How much is the parts to be replaced?
Below is a link to a service manual. You will have to join the site and be logged in to be able to download the manual. http://appliancejunk.com...wnloads;sa=view;down=283You have to be careful as the manual covers several different units. Looks like F1 is an EOC (control board) error. Before replacing it I would unplug the unit for several minutes to see if it will reset and clear the error. You will have to call AppliancePartsPros if you need a control board as it does not come up when I search using the given model number. |
THIS FORUM IS DEAD!!!!!!! |
