meverett5133
#1 Posted : Sunday, May 10, 2009 2:44:04 PM(UTC)
meverett5133
I push the start button and I hear a large thunk sound and then will get what sound like the water pump working but no water. Then I'll press the start button again and the dishwasher sounds like its running a cycle but without water. Every once in a while I can get the dishwasher to actually work correctly but most of the time I can't get it to fill with water.
#2 Posted : Tuesday, May 12, 2009 4:31:34 AM(UTC)
Replacement parts for GE GHDA480N00WW | AppliancePartsPros.com
Check to be sure the foat is not sticking in the up position.
This flood switch disconnects power to the water valve if it is not activated.
Check that the water valve is getting power when it should with a meter (120 volts).
If it is getting power and not opening then it needs replacing.
meverett5133
#3 Posted : Tuesday, May 12, 2009 5:01:27 AM(UTC)
meverett5133
Thanks for the info. Where is the "foat" or "float" located at?
#4 Posted : Tuesday, May 12, 2009 5:24:45 AM(UTC)
Front right hand side in the tub.
Switch is Item 3089 in the "Body parts" section
meverett5133
#5 Posted : Tuesday, May 12, 2009 5:57:24 AM(UTC)
meverett5133
I looked at the Tub Diagram for the GE GHDA480N00WW and found the float on the front left side. Anyway, my question is regarding the testing of the water valve using a voltmeter. I've read the Sticky on voltmeter use so if I disconnect the power and check the two contact points on the water valve, should the voltmeter be showing 0 or infinity. Sorry, I'm a total electric newb. From what you said, if it showing "0" and not getting water I should replace the valve. Is that correct?
#6 Posted : Tuesday, May 12, 2009 6:30:39 AM(UTC)
OOPS! Must have had my head up my you know what or I just need another cup of coffee
Should be reading some resistance, am not sure how much.
It will not be 0 as this would be a short and would blow your breaker.
If it is infinity then the coil in the valve is open and it needs replacing.
Use a high meter scale to check for infinity as a the coil may be outside the range on a low scale and show infinity when in actuality there is resistance
Not to worry, everyone was a newb at one time
Just check it for resistance.
Note that the coil in the valve may be OK and the valve still will not open. So if you get a resistance, reattach the wires to the solenoid, set your meter to AC volts on a 200 volt scale and start a cycle. If the valve gets 120 volts and does not open then it is the valve for sure.
Guest (4)
