flymom
#1 Posted : Sunday, July 27, 2014 11:14:15 AM(UTC)
flymom
I need the order of the wire placement for this ice dispenser motor: W10271507
There are 3 pins, then a space, then 3 more pins. I have a total of 6 pins, 7 ports on the terminal, and 4 wires. The brown/white is on one end, and right next to it is a red/white. The problem is that I also have a blue wire and a gray wire and not sure which port they go in as they were corroded and came out of terminal. I have seen 2 different answers on this forum, one is: brown/white, red/white, N/C, N/C, Gray, N/C, blue but that was for a different model of frig but looked like same motor. Another entry I saw was: red/white, brown/white, n/c, n/c, n/c, blue, gray. I don't think this is correct as my brown/white and red/white are still intact in the terminal and similar to first scenario. If there is anyone out there that has this model, could you please remove plate on freezer door just about shelves and take a peek? It would be greatly appreciated! Thanks.
#2 Posted : Monday, July 28, 2014 1:36:45 AM(UTC)
Just in case someone else does not actually check the wires for you.
It shows the hook up as
Br/Wh - Rd/Wh - N/C - N/C - Gy - N/C - Bu
File Attachment(s):
KSSC42.pdf (944kb) downloaded 14 time(s).
flymom
#3 Posted : Monday, July 28, 2014 6:49:38 AM(UTC)
flymom
Thanks Denman!! I really appreciate it!! Thats exactly what I was looking for.
