Missing tech sheet. Not heating. Already replaced element.
Here are your parts Parts for WDT710PAYM - AppliancePartsPros.comSee the attachment for the tech sheet would check at the control board ( P4-4 to P4-3). Should be around 30 ohms. That way you check the wires, the heater and the hi-limit in one go. |
THIS FORUM IS DEAD!!!!!!! |
