jetski
#1 Posted : Tuesday, May 5, 2009 4:36:17 PM(UTC)
jetski
Guys this thing is crazy wild goes like normal them comes the spin cycle and it shaks the house machine is level I took front panel off and tried to hold it like a shock it got a little better can it be fixed or is it shot gun time :D
sidfink43
#2 Posted : Wednesday, May 6, 2009 8:49:36 AM(UTC)
sidfink43
Since you did not post a model number, I am assuming this is a standard top loading GE washer.
It sounds like you have ruled out the suspension rods, but check each one again as they are your likely problem.
If they are not the problem, look at the clutch assemby that is attached to the motor. In spin mode it should not be moving, and the belt should be horizontal, and not moving up or down.
Let us know what you find, and if you need additional help post the model number and any other info you can think is helpful.
Good luck!
jetski
#3 Posted : Sunday, May 10, 2009 10:35:29 AM(UTC)
jetski
it is a front loader model #wsxh208a1ww
sidfink43
#4 Posted : Sunday, May 10, 2009 1:10:41 PM(UTC)
sidfink43
Ok, forget the suspension rods. What you probably have here is a broken air shock. Run the machine with the back cover off so you can see what is going on and see if you can determine if that is the problem.
This is a pretty good machine so I would recommend fixing it, but GE parts are notoriously expensive, so you better be certain that the air shocks are the problem before you invest in them.
Good luck and let us know what you decide and how it works out.
