TOBY1938
#1 Posted : Wednesday, July 23, 2014 8:42:08 PM(UTC)
TOBY1938
I Have A Kenmore Dryer That Won't Shut Off. The Timer Advances And The Cool Down Works Ok, But At The End Of The Cycle It Continues To Run. If I Open The Door It Stops, But If I Push The Start Button The Drum Starts Up Again. I Installed A New Timer But It Didn't Cure The Problem.
fairbank56
#2 Posted : Thursday, July 24, 2014 9:34:35 AM(UTC)
fairbank56
Groups: Expert
We need a model number???
Eric
TOBY1938
#3 Posted : Thursday, July 24, 2014 2:25:35 PM(UTC)
TOBY1938
My Model Number Is Kenmore Dryer 11096273800.
Serial Mc3543538. Won't Shut Off!
fairbank56
#4 Posted : Thursday, July 24, 2014 3:28:28 PM(UTC)
fairbank56
Groups: Expert
Check the power resistor near the timer. Should read 4000-5000 ohms. Looks like this.
Eric
UserPostedImage
Replacement resistor is different type.
http://www.appliancepartspros.c...or-279872-ap3094277.html
TOBY1938
#5 Posted : Thursday, July 31, 2014 4:35:25 PM(UTC)
TOBY1938
Fairbank56
Eric, Thank You So Much. I Ordered The Part You Said Might Fix The Problem I Had With My Dryer. After It Came I Installed It And It Cured My Problem. The Total Cost Was Only $7.49. Again Thank You So Much.
From Your New Friend,
Toby Matherly
Kenmore dryer won't shut off (Dryer Repair)
by Jerrycurl 5/28/2013 3:39:08 PM(UTC)
by metsmaniac 7/29/2011 8:44:33 AM(UTC)
