joker35
#1 Posted : Tuesday, July 22, 2014 3:55:06 PM(UTC)
joker35
Hello,
Dryer is now showing error code E68. I tried to enter the test mode by pressing START & CANCEL for 10 secs but no reaction from the dryer. Since the error code appears to indicate a key being stucked I worked all the keys and none seams to be actually stucked. I noticed that pressing the DRYNESS key didn't result in the dryness actually being changed as per LED indicated.
Any idea what I should do next?
Regards
Lars
#2 Posted : Thursday, July 24, 2014 12:48:15 AM(UTC)
I cannot find any info on the given model number.
It sounds like you have found the problem re: "I noticed that pressing the DRYNESS key didn't result in the dryness actually being changed as per LED indicated.".
I would say that this is the bad key.
I do not know what part to replace control board or the keypad if it uses a separate keypad and control board.
joker35
#3 Posted : Thursday, July 24, 2014 12:33:53 PM(UTC)
joker35
Thanks for the reply; perhaps I read the model no. wrong.
The correct model# appears to be: GLEQ2152ESO.
Any assistance is greatly appreciated.
#4 Posted : Friday, July 25, 2014 1:36:21 AM(UTC)
Parts for Frigidaire GLEQ2152ES0 Dryer - AppliancePartsPros.com
Since all the buttons seem to be free the problem is probably on the control board.
File Attachment(s):
GLEQ2152.pdf (280kb) downloaded 14 time(s).
Guest (4)
Frigidaire Affinity error code E68 (Washer Repair)
by ericdiy 5/21/2011 12:43:54 PM(UTC)
Error code E68 (Dryer Repair)
by randress 12/31/2010 6:36:16 PM(UTC)
Error Code E68 On Dryer (Dryer Repair)
by Siorai 7/31/2010 2:15:28 PM(UTC)
