3 Pages<123>
sea157
#11 Posted : Wednesday, July 23, 2014 3:33:44 PM(UTC)
sea157
Eric,
I do have continuity on the wrinkle guard switch.
But what terminals on the start switch do I use to check it for the buzzer?
Also what triggers the motor to start in the wrinkle guard cycle?
If it is the timer I just replaced the timer and the wrinkle guard is still not working.
fairbank56
#12 Posted : Wednesday, July 23, 2014 4:09:18 PM(UTC)
fairbank56
Groups: Expert
There should be either a tan or black wire from the buzzer to the start switch. Disconnect that wire from start switch and check continuity between that terminal on switch and the terminal that the pink/black wire connects to. It is the timer that turns the motor on/off during wrinkle guard.
Eric
sea157
#13 Posted : Wednesday, July 23, 2014 5:08:08 PM(UTC)
sea157
Eric,
I do have continuity between the black wire and the pink/black terminal.
I rechecked the buzzer by wiring it to an extension cord and plugging it into electric and it buzzes.
But once hooked into the dryer it will not buzz at the end of the cycle and the wrinkle guard cycle is still not working.
Is there anything else the wrinkle guard cycle and the buzzer has in common? :confused:
I already installed a new timer.
fairbank56
#14 Posted : Wednesday, July 23, 2014 5:36:17 PM(UTC)
fairbank56
Groups: Expert
Unplug the black wire from the start switch. Stick a piece of wire into the quick disconnect terminal. Start the dryer. Holding only the insulated portion of the black wire, touch the wire to one of the terminals on the start switch that the blue wires are connected to. The buzzer should sound. If it doesn't, then looks like the motor switch has defective contact or there is a problem with the other black wire from the buzzer to the motor wiring harness connector.
You do realize that wrinkle guard is an extension of the auto dry cycle. The dryer must be running as timer goes into wrinkle guard. If you open the door at end of auto cycle before it goes into wrinkle guard, the motor won't start by itself in wrinkle guard. In wrinkle guard the dryer should come on for 15-30 seconds every 5 minutes. If door is opened, start relay will open and you would have to press start switch again to get it started but timer would have to be in correct position for this to work. Is timer advancing in wrinkle guard even though drum drive motor is not running? It should be.
Eric
sea157
#15 Posted : Wednesday, July 23, 2014 5:49:51 PM(UTC)
sea157
Eric,
I will try the test for the buzzer tomorrow and let you know.
Yes I do know that wrinkle guard is only an extension of the auto dry cycle and I never opened the door just to see if it was working and it is not working. (Not tumbling every 5 minutes like it should, not tumbling at all)
Yes the timer is advancing in the wrinkle guard cycle but it seems to make a rattling sound just like the old timer did.
sea157
#16 Posted : Thursday, July 24, 2014 5:26:36 AM(UTC)
sea157
Eric,
I did the below test for the buzzer and the buzzer will buzz.
But it buzzes with the buzzer switch set to the on or off position with this test.
So what does this tell us and does that narrow my problem down?
Test preformed
fairbank56
#17 Posted : Thursday, July 24, 2014 5:29:00 AM(UTC)
fairbank56
Groups: Expert
While timer is advancing in wrinkle guard, press the start button. Start relay should engage and stay engaged. Motor should start within 5 minutes. If not, it sure sounds like a bad timer. You should have 120vac between timer T terminal and start switch blue wires (both of them). If so but motor never starts during wrinkle guard cycle, then the timer is bad. Timer should connect T to W when it's time for motor to run in wrinkle guard.
As for the buzzer test, it tells me that the motor switch is ok and again points to a timer problem. If your at all familiar with reading the wiring diagram, I can try to explain how it should work but if it's just greek to you, probably a waste of time.
Eric
sea157
#18 Posted : Thursday, July 24, 2014 5:41:21 AM(UTC)
sea157
Eric,
Could I test this by touching a jumper wire from terminal T to W while the timer is in the wrinkle guard cycle?
Should the motor start in the wrinkle guard mode by doing this test?
Also what do my results from the buzzer test tell us?
Thanks Steve
fairbank56
#19 Posted : Thursday, July 24, 2014 5:44:58 AM(UTC)
fairbank56
Groups: Expert
Originally Posted by: sea157 Go to Quoted Post
Eric,
Yes to both. As for the buzzer test, it tells me that the motor switch is ok and again points to a timer problem. If your at all familiar with reading the wiring diagram, I can try to explain how it should work but if it's just greek to you, probably a waste of time.
Eric
sea157
#20 Posted : Thursday, July 24, 2014 6:10:24 AM(UTC)
sea157
Eric,
I will try touching a jumper wire from T to W and let you know what happens.
Maybe I bought another defective timer. :eek:
3 Pages<123>
