Trebortrebor235
#1 Posted : Tuesday, July 22, 2014 11:08:27 PM(UTC)
Trebortrebor235
Our dryer only heats on the timed settings. If I use the intellidry setting it will not ignite. Where would I go to find the problem. Is it in the panel or a separate sensor that is used on that cycle?
fairbank56
#2 Posted : Wednesday, July 23, 2014 5:16:27 AM(UTC)
fairbank56
Groups: Expert
Trebortrebor235
#3 Posted : Wednesday, July 23, 2014 6:37:20 PM(UTC)
Trebortrebor235
Eric
I will give that a try. Thank you. Will use your web site to order the part
Bob
Trebortrebor235
#4 Posted : Saturday, July 26, 2014 7:09:27 PM(UTC)
Trebortrebor235
I found that it will ignite but only hear for about 2 min then the flame stops but dryer stays running with no heat. Could it be a sensor?
fairbank56
#5 Posted : Sunday, July 27, 2014 3:37:47 AM(UTC)
fairbank56
Groups: Expert
In both timed dry and auto dry? Did you replace the timer?
Eric
