My kitchen aid washer makes funny noise only on the hot/cold fill cycle. Would it be a fill valve solenoid?
Thanks,
It is almost impossible for us to diagnose a noise problem like this without being there to hear it.
If it is truly bothersome then I would change out the valve assembly; otherwise if it is not affecting the operation of the machine I would recommend you try to live with it and see what happens.
