May tag bottom freezer. The door to main compartment light does not come on when opened, I have to tap the switch for it to come on. any suggestions to adjust switch?
[COLOR="Blue"] any suggestions to adjust switch[/COLOR]? I doubt there is any adjustment. In any case you said that you have to tap it so it does not sound like it is just not a case of the switch activator not being pushed in enough.
Why not just replace the switch. |
THIS FORUM IS DEAD!!!!!!! |
