How many connections are on the cold control? Is the wiring diagram available?
Below is the thermostat Part number: AP3120051
I cannot find a wiring diagram for this unit. The thermostat will have two connectors. It may have a third connector but it will be obvious that this connection is the metal body of the thermostat and it is connected to a ground wire if this unit has one. |
THIS FORUM IS DEAD!!!!!!! |
