ehenry
#1 Posted : Thursday, July 17, 2014 5:20:05 AM(UTC)
ehenry
Last night while using both d ovens we hear two beeps a puase then one beep and the display was dark except for error codes. There was an E2 in the middle of the display and on the extreme right side there is an F3.
I'm not quite sure how to interpret these error codes.
#2 Posted : Thursday, July 17, 2014 6:13:05 AM(UTC)
Nothing comes up using the given model number.
Please check it.
Find your model number - AppliancePartsPros.com
ehenry
#3 Posted : Thursday, July 17, 2014 12:20:23 PM(UTC)
ehenry
The oven is going on 15 years old. This is the first problem we have had with it. I guess its possible that being that old you wont find anything on it. When I google the model number nothing comes up. Its the model number that is on the right side of the upper oven when you open the door.
I shoot a picture of the model number and the front of the oven itself and post it tomorrow.
ehenry
#4 Posted : Friday, July 18, 2014 1:12:15 PM(UTC)
ehenry
KEBS207BWH6 - I used the hidden function of the keys to get the codes
UserPostedImage
#5 Posted : Saturday, July 19, 2014 2:21:39 AM(UTC)
Attached is a tech sheet. It is for a BWH2 unit but yours should be the same.
Here are the parts, also for a BWH2
Parts for Whirlpool KEBS207BWH2 Wall Oven - AppliancePartsPros.com
Looks like a F3 E2 is an over temperature error.
Have you tried removing power from the unit for a couple minutes to see if the error/microprocessor will reset?
If this clears it then check that the fan is OK.
If this does nothing I would check the oven sensors.
Below is a link on this, take a look at 7, 8, 20 and 21.
http://www.applianceaid.com/ele...-range-repair-topics.php
File Attachment(s):
KEBS207.pdf (383kb) downloaded 0 time(s).
Guest (4)
