what is the proper ohm reading on my defrost heater...I get a reading of .03 ohms when set at the 20k range....is this correct or does it need changed?
Your meter scale is way too high. Use the 200 ohm scale.
It will probably be in the 20 to 50 ohm area. |
THIS FORUM IS DEAD!!!!!!! |
