AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Frigidaire Washing Machine - Will not fill but will spin and agitate
Frigidaire Washing Machine Model FWSB6600ES0
The washer will not fill with water but will spin and agitate. I am trying to determine if the pressure switch is bad or if the water inlet switch is bad.
I have the pressure switch out to test.
Can you tell me how to test the switch with an ohm meter? I no little about using the meter and am not sure what the meter should read to indicate a good switch or bad switch.
I have an ohm meter and if I touch terminal 1 (ro) and 2 (vl), the meter will go from infinity to zero and if I blow into the switch is returns to infinity.
If I touch terminals 2 (vl) and 3 (pr), the meter stays at infinity and if I blow into the switch, the meter goes to zero.
I sounds like your switch is bad, here is a link to the service manual which discussed the switch on page 36. http://www.emaservicetips.com/pdfs/489_5.pdfGo ahead and replace it, and if you buy from this site and it is not the switch but the timer instead you can replace it.
Washer Repair
