bdogm
#1 Posted : Thursday, July 10, 2014 9:15:21 AM(UTC)
bdogm
Fridge and freezer not cold enough. Temps in freezer around 3-5 celcius and fridge 8-10 celcius. Evap fan working, condensor coils cleaned, compressor running, replaced defrost timer, tested defrost heater its heating, coils have frost on bottom coil not heavy frost, replaced start device, replaced fridge thermostat, door seals ok. Help?
#2 Posted : Thursday, July 10, 2014 10:59:42 AM(UTC)
Sounds like a sealed system problem.
This will be an expensive repair as you need a pro.
Often it makes more sense to put the dollars towards a new unit.
I am assuming that the compressor runs all the time other than when the unit goes into a defrost cycle.
Also that the compressor ran for at least an hour before you checked it and found frost on just the bottom of the evaporator/freezer.
Below is a link, take a look at the example pictures part way down the page.
http://www.applianceaid.com/ref...ator-not-cold-enough.php
