My side by side refrigerator and freezer aren't cold at all. We cleaned off the coils and still not cool. The lights are all on and you can hear the fans working. CouLd it be the thermostat or compressor? Model # is 10658972700
I am assuming that "aren't cold at all" means that there is no cooling at all.
You have to find out if the compressor is running. You can usually hear it but also should be able to feel it vibrating.
If it is not on then it could be a control or a start devive problem.
If it is on then it is probably a sealed system problem. |
THIS FORUM IS DEAD!!!!!!! |
I have a frigadare refrigerator side by side model #plhs267zab6 the freezer does not want to freeze I have change the relay switch and the thermostat sensor the compresser turns on and I added Freon but the freezer wont freeze
machooppr
Please start your own post using Post New Topic in this section. Adding to a different unit's post will just confuse things for the original poster. |
