2 Pages12>
br412
#1 Posted : Friday, May 8, 2009 11:58:37 AM(UTC)
br412
Have had frost building up on inside of rear panel in freezer.
Temps get higher in freezer and in food section.
This has been in past 6 months, but maintaining correct temps has always been a chore, even before the frost buildup.
Using hair dryer(to remove frost AND ice from coils) does help maintain normal temps for a few days, then need to use the hair dryer again.
How do I know if I just need the Control Timer (behind panel in food section) or whether its the thermostat in the freezer, or if I need the Defrost Heater Kit which has the thermostat and the heater?
Thanks Bill
#2 Posted : Friday, May 8, 2009 4:19:12 PM(UTC)
Hi Bill,
The first thing I would do is slowly turn the shaft on the defrost timer until it clicks and watch if the defrost heater energized. If it does then the defrost timer is the culprit.
If it does not then you have to check the defrost heater and the defrost thermostat for continuity. If the heater has gone bad it should be pretty visible.
Here are the breakdown diagrams and Replacement parts for GE TFS22PPDABS | AppliancePartsPros.com
br412
#3 Posted : Sunday, May 10, 2009 4:50:51 AM(UTC)
br412
Thank you very much. I will follow your advice.
Great turn around response and will advise when I can
Bill
Jim Plack
#4 Posted : Sunday, May 10, 2009 8:25:18 AM(UTC)
Jim Plack
I too am having a problem with my GE Profile building up ice on the back wall of the freezer.
But all my food has thawed and the refrigerated food section has gone warm.
I rescued the food, but wonder if this can be easily repaired or is it time for a new unit?
Any ideas?
Jim
br412
#5 Posted : Sunday, May 10, 2009 11:47:53 AM(UTC)
br412
Hi Gene
Well, did as you suggested But not knowing how sensitive the defrost timer was, I turned too forcefully and it clicked twice.
Does this mean it will miss a cycle and wait another 24 hours ?
If I unplug it, will; it reset itself to "get back into an immediate defrost cycle" ?
Always a novice...but will be an expert on this job.
Thanks Bill
#6 Posted : Sunday, May 10, 2009 1:29:27 PM(UTC)
Any ideas?
Jim
Jim,
What is the complete model number of the refrigerator?
#7 Posted : Sunday, May 10, 2009 1:31:51 PM(UTC)
Originally Posted by: br412 Go to Quoted Post
Hi Gene
Thanks Bill
Hi Bill,
Wait until you'll hear the compressor running and then turn slowly the defrost timer clockwise until it clicks. The compressor must stop right after that click.
br412
#8 Posted : Sunday, May 10, 2009 3:10:19 PM(UTC)
br412
Hi Gene
You there Sunday. Amazing.
Yes, if I go through enough clicks while compressor is running...it does stop running.
What does that mean? Does it mean that the refrigerator is about to enter defrost mode?
I looked at the heating unit and didn't see any melting or is that something I won't see for some time?
Once comprerssor stops running..in time sequence, how long does it take to enter defrost mode and what should I see happening in the freezer./coils which are coated with frost.
Thanks again. Bill
#9 Posted : Sunday, May 10, 2009 11:43:46 PM(UTC)
Bill,
As soon as the timer clicked and the compressor stopped the refrigerator must be in the defrost. You can find much more information in one of our previous articles: http://forum.appliancepartspros...frigerator-too-warm.html
br412
#10 Posted : Monday, May 11, 2009 7:36:03 AM(UTC)
br412
Gene Good Morning
Well, it goes through the defrost cycle...no sizzle, no melting of frost,
so will order up the heater kit. Not taking chance that thermostat works or doesn't
I thank you for your help.
Bill
GE Profile Freezer Wildly Varying Temps (Refrigerator & Freezer Repair)
by Guest 3/26/2024 3:54:40 PM(UTC)
Water dispenser not working GE Profile PSHs6TGXBDS (Refrigerator & Freezer Repair)
by klkaylor78 2/3/2024 11:07:08 AM(UTC)
GE Profile PSC23SGPA (Refrigerator & Freezer Repair)
by dwhit 10/3/2023 10:25:11 AM(UTC)
Whirr whirr whirring sound from my GE Profile PFE28RSHHSS refrigerator (Refrigerator & Freezer Repair)
by Guest 4/29/2023 7:48:19 AM(UTC)
GE Profile refrigerator PY model - chime not working (Refrigerator & Freezer Repair)
by Guest 2/7/2023 8:07:10 AM(UTC)
GE Profile erratic temperatures (Refrigerator & Freezer Repair)
by david2u 2/4/2023 9:51:52 AM(UTC)
Buy (300 Pieces) New GE Profile - Opal 2.0 38-lb. Ice Maker Dispenser $134,700 (General Talk)
by eikohajime30 1/4/2023 11:05:58 PM(UTC)
Dishwasher Repair for GE profile (Dishwasher Repair)
by Guest 12/10/2022 11:15:25 AM(UTC)
GE Profile Range Timer Button Not Working (Oven Repair (including Ranges and Cooktops))
by Bush444 11/23/2022 10:11:35 AM(UTC)
Dishwasher GE PROFILE MODEL PDT825SSJSS (Dishwasher Repair)
by apeconsulting 9/13/2022 9:02:22 PM(UTC)
GE Profile ice maker intermittently worked, now completely dead (Refrigerator & Freezer Repair)
by wolfpack95 8/29/2022 7:27:03 AM(UTC)
GE profile replace motor WH20X10009 (Washer Repair)
by Guest 6/25/2022 3:05:26 PM(UTC)
My GE Profile PSB42YSXASS refrigerator (Dishwasher Repair)
by anderdan 6/13/2022 8:44:34 AM(UTC)
GE Profile pdwt380vd00ss Inner Rail Upper Track (Washer Repair)
by tsak175 5/8/2022 7:02:24 AM(UTC)
GE profile refrigerator PSC25MSWC (Refrigerator & Freezer Repair)
by Guest 5/7/2022 9:36:17 AM(UTC)
2 Pages12>
