My gear box is leaking and I can buy new seals but I do not know what kind of oil or how much to put in. does any body know the answer to this?
Hi, sorry not to have replied ealier but there was a similar post to yours and as a result I missed your posting.
You can use GS 90 weight oil, and fill the transmission up to just below the cover.
Originally Posted by: sidfink43  Hi, sorry not to have replied ealier but there was a similar post to yours and as a result I missed your posting.
You can use GS 90 weight oil, and fill the transmission up to just below the cover. What do you recommend using to reseal the cover?
You should be able to order the seal form this site or from that parts supplier of your choice.
how will fill the gearcase?
