ARS2664AC
#1 Posted : Saturday, May 9, 2009 11:47:56 PM(UTC)
ARS2664AC
Replaced my water valve, the ice maker no longer leaks, makes ice. But now, the ice dispenser does not work. Doesn't seem to be getting any power. The Auger does not turn, no motor noise. The water dispenser works fine. Please advise. Thanks in advance for your responses.
ARS2664AC
#2 Posted : Sunday, May 10, 2009 8:59:52 AM(UTC)
ARS2664AC
Me again! Behind the water valve I replaced there appears to be another valve located behind the water valve. Could this model have 2 water valves? Does the other valve need replacing too? BTW, the icemaker is overflowing again. Thanks in advance for your responses.
Question on the plugs: One is brown, the other clear. Does it matter which terminal the plug is plugged into?
ARS2664AC
#3 Posted : Saturday, May 16, 2009 11:40:05 PM(UTC)
ARS2664AC
It turns out that I had to replace both the primary and secondary water valves. Once done, all is now well in the world of my Amana Refrigerator. Problem resolved.
Guest (4)
