Eric L
#1 Posted : Monday, June 30, 2014 6:12:00 AM(UTC)
Eric L
I am having a problem with the oven maintaining temperature. The over will heat up to the desired temperature, but over time the temp. will reduce. As an example, the over was set to 350 and approx one hr later, it registered approx 225 on a thermometer. I have replace the temperature sensor.
#2 Posted : Tuesday, July 1, 2014 3:16:01 AM(UTC)
I cannot find any info on the given model number.
Are you sure that it has the 'O" in it?
Since you have already replaced the sensor I would say that the control board is bad.
Eric L
#3 Posted : Wednesday, July 2, 2014 6:32:47 AM(UTC)
Eric L
Yes the serial # is as stated. It does come up with a parts list when entered.
I was hoping not to have to spend 300 on an older range for the controller
