I have a Whirlpool Quiet Partner I dishwasher. The heating element went out and I replaced it. It still does not dry and I am trying to figure out how to do a reset. Everything I keep finding online says to hit "heated dry, normal, heated dry, normal" within 3 seconds, some say door open some closed. no matter how I try it, it isn't doing anything but cycling through the lights. The buttons I have are: 1. "Pots and Pans/ Normal/ 1 Hour Wash" 2. "High Temp/ Heated Dry" 3. "4 Hour Delay" 4. "Start/ Resume" 5. "Cancel/ Drain"
Does anyone know the real way to reset this blasted machine??!?!?!! Thanks!
As an update, I pulled the fuse and when the multimeter is set to 200 OHM it is reading 00.4
