curbalertband
#1 Posted : Friday, June 27, 2014 12:35:19 PM(UTC)
curbalertband
will check on model number when i get home but wanted to ask first...when oven is running, we get a really loud fan noise coming from (I think) the space in between the upper and lower ovens. I'm sure something is loose, but i need to get some help diagnosing the problem.
Hopefully its just an old fan that has become loose and worst case, needs to be repaired.
Anyone have a link to troubleshooting guide?
Also, the handle on the upper oven is loose, and i want to tighten it but can't tell how it's actually attached.
thanks!
#2 Posted : Tuesday, July 1, 2014 3:20:38 AM(UTC)
Need a model number in order to be able to see if a service manual is available.
