Dumbounded
#1 Posted : Monday, June 30, 2014 6:08:21 PM(UTC)
Dumbounded
Not sure if it is shorting out or what.
The dryer will turn on but NO heat. :confused:
The washer only turns on when the dryer is running. :mad:
Thanks for your help!
#2 Posted : Tuesday, July 1, 2014 2:04:14 AM(UTC)
Parts for Frigidaire FEX831FS4 Washer Dryer Combo - AppliancePartsPros.com
Here is a wiring diagram.
http://manuals.frigidaire.com/p...df/Webster/137060900.pdf
I would stat by checking the power.
Could be that you are missing half the line therefore no heat and that the washer is getting power from the otherside of the line through a part in the dryer.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
