JimKern1
#1 Posted : Sunday, June 29, 2014 9:48:12 AM(UTC)
JimKern1
I'm having a problem with not enough water for the machine to function. I get a surging sound as the pump keeps running out of water. If I add a half gallon of water it runs fine. I think the trouble is my low water pressure. I have removed, cleaned and inspected the fill valve and and replaced the valve under the sink. don't believe those are the problem. my question is, is there a way to make the control board allow more time for the tub to fill?
JimKern1
#2 Posted : Sunday, June 29, 2014 2:33:41 PM(UTC)
JimKern1
As it turned out, it was the fill valve. I found a almost compatible one and made it work as a test and it put out much more water and ran the wash cycle just fine. I'll order the correct part and I'm sure it will be fine.
Not enough water in the tub (Dishwasher Repair)
by larc 2/5/2010 7:19:59 AM(UTC)
