2 Pages<12
#11 Posted : Sunday, June 29, 2014 1:29:01 AM(UTC)
The thermistor is wired in the damper control, so instead of replacing it, just replace the thermistor. Get it's part # in the sticky above and info on it's resistance at room temperature so you can test it.
#12 Posted : Sunday, June 29, 2014 1:31:53 AM(UTC)
Sticky, ( GE refrigerators ( GS* and PS*) models.
#13 Posted : Sunday, June 29, 2014 5:27:41 AM(UTC)
The part # is AP3185407
waltenk
#14 Posted : Sunday, July 13, 2014 7:34:00 PM(UTC)
waltenk
Richappy - got the thermistor and took apart the damper. This looks like a sealed unit where the coiled sensor feeds into a bellows of some kind that expands to drive a probe to push a switch (cooling on/off?).
I do not see how to replace the sensor with the new style thermistor. Is that possible, or is my appliance too old? Do I need to order the full damper unit?
Pix attached...
waltenk attached the following image(s):
#15 Posted : Monday, July 14, 2014 12:48:29 AM(UTC)
So there is no thermistor in the damper package. If so, you will need to study the breakdown diagrams to find it.
Guest (5)
2 Pages<12
