rlabbe
#1 Posted : Friday, December 14, 2007 11:19:51 AM(UTC)
rlabbe
Ice builds up below evaporator fan making loud noise and eventually preventing fan from turning; rear drain is clear
#2 Posted : Friday, December 14, 2007 1:27:31 PM(UTC)
If you are sure the drain is open, then the problem is a faulty defrost system which consists of three parts: the defrost timer (#47 on the #4 break down diagram), the defrost heater (#11 on the same break down diagram) and the defrost thermostat (#10 on the same break down diagram).
You can find the instructions for the troubleshooting in one of my previous posts: http://forum.appliancepartspros...er-works-not-fridge.html
- The part number for the defrost timer is AP2061693
- The part number for the defrost heater is AP2071519
- The part number for the defrost thermostat is AP2071271
- Here are the break down diagrams for the GE refrigerator Model GBS18KBMACC
