appitaffi
#1 Posted : Saturday, June 21, 2014 6:13:04 PM(UTC)
appitaffi
My Amana refrigerator with bottom freezer is running warm. Ice cream melt and ice maker doesn't make ice any longer. I'm totally novice in this field but I watched some repair videos and read your forums and started to figure out the problem. Here is what I did so far.
1. checked both fans are working well
2. cleaned all the dust from condenser fan but could reach out the black coil on the bottom so could clean them.
3. check continuity of compressor and came out around 6 ohm-7 ohm-14 ohm, they are little much than the safe boundary but seems okay since the pipe from the compressor is cold. And I could here the sound of clicking and buzzing sound as usual.
And I found the frozen wall in the freezer so I opened it up the wall and blew it off until nice and clean. So I expected I freezer comes back to life but it didn't.
Could you advise me what if you can determine the root cause based on the above? Thank you!
#2 Posted : Sunday, June 22, 2014 2:20:33 AM(UTC)
Parts for Amana ARB2557CSR / PARB2557CS1 - AppliancePartsPros.com
[COLOR="Blue"]And I could here the sound of clicking and buzzing sound as usual.[/COLOR]
I am not sure what you mean by the above.
Th compressor should not be doing a lot of clicking as this is a symptom of it trying to start. For some reason it cannot and then the overheat trips and it retries once the compressor cools down.
First thing you want to check is if the compressor is running all the time except when the unit goes thru a defrost cycle. You can usually hear it but also should be able to feel it vibrating.
It should be on all the time as your freezer temperature is high so it should be trying to cool it down.
If it is on all the time, is the evaporator/freezer fan also on?
If both are on, remove the rear cover in the freezer and check the evaporator coils.
If they are iced/frosted over to the point that the fan cannot pull air through them you have a defrost problem.
If there is just frost in one area (usually where the freon enters the coils) then it is probably a sealed system problem. This will be an expensive repair as you need a pro.
appitaffi
#3 Posted : Monday, June 23, 2014 3:46:09 PM(UTC)
appitaffi
It doesn't keep clicking and buzzing.
--> [COLOR="Navy"]No, it doesn't run all the time. yes I could hear it and also feel it. Once it clicks, buzzing is following and it goes for a while. But it stops. And when compressor is running, evaporator fan runs as well. I think here is the suspicious point. Even thought the temperature is high, the compressor is not running all the time.
[/COLOR]
--> I removed all the ice from the coils but it is not alive.
--> The frost was over half of the entire coils, does it seem okay?
#4 Posted : Tuesday, June 24, 2014 2:19:40 AM(UTC)
[COLOR="Blue"]--> No, it doesn't run all the time. yes I could hear it and also feel it. Once it clicks, buzzing is following and it goes for a while. But it stops. And when compressor is running, evaporator fan runs as well. I think here is the suspicious point. Even thought the temperature is high, the compressor is not running all the time.[/COLOR]
Yes the compressor should be on all the time except when in a defrost cycle.
The above points to a bad main control thermostat as the unit is cycling but is shutting off too soon.
You could check this by unplugging the unit and shorting the two wires at the control thermostat together. Just be sure they cannot short to anything else. Then plug it in and monitor the freezer temperature If it gets down to 0 to 5 degrees F then you know that the unit is capable of doing this and it is just a control problem.
Do not leave the thermostat shorted. This is just for testing.
If it does not get down to the temperature and cycles then it is probably a sealed system problem. The compressor is overheating and it's thermal protect is opening killing power to it. Then when the compressor cools the protect resets and the compressor restarts.
[COLOR="Blue"]--> I removed all the ice from the coils but it is not alive.[/COLOR]
Not sure what you mean by "alive"
If the coils were heavily iced/frosted over re : a defrost problem, and you manually defrost the unit then it should work OK for at least a couple days until the ice/frost builds up again impeding air flow.
[COLOR="Blue"]--> The frost was over half of the entire coils, does it seem okay?[/COLOR]
Should be a fairly even coating over the entire coil surface but sometimes it depends when you checked it.
Below is a link, check out the example pictures about half way down the page.
http://www.applianceaid.com/ref...ator-not-cold-enough.php
Kevmag1
#5 Posted : Wednesday, June 25, 2014 11:47:45 AM(UTC)
Kevmag1
Same thing happened to me.
My fan was working so I didn't think it was the problem.
It turned out that that it wasn't blowing hard enough.
I put in a new one and that fixed it.
