darticus
#1 Posted : Saturday, June 21, 2014 10:58:03 AM(UTC)
darticus
Can anyone suggest a solution. The right door is hanging lower than the correct left door. Are these easy to adjust. Can anyone tell me how to go about it? Still runs real good. Thanks Ron
darticus attached the following image(s):
#2 Posted : Sunday, June 22, 2014 1:55:50 AM(UTC)
You seem to be missing several letters at the end of your model number.
If you look up your model number in the parts and then look at the hinge, you will see they uses a cam on the hinge and the door perhaps this is broken.
If you click on a part's description or picture a new page will open often with more info about that part.
