I have a small Malber WD1000 vent less washer and dryer installed in my boat. It appears that I overloaded the unit and the drum no longer rotates. I can rotate the drum and motor by hand freely. The belt is tight and in good condition. The motor does not spin in washer or dryer mode. When the washer is turned on and the cycle dial set to various positions, I hear a slight humming noise from the area of the timer, but the motor appears to be completely dead. Is there possibly a reset-able circuit breaker somewhere? I could not find a phone number for Malber USA that worked. Do you know of any contacts for the manufacturer? Thanks for your help.
Did you find anything out? Bad motor or is there a reset switch?
