kplumeriat
#1 Posted : 11 years ago
kplumeriat
Last night my Whirlpool Washer was filled with water in the load I was doing. I moved the knob to different cycles in all the settings, only to get a humming noise. After scooping out the water, it would work on the Rinse cycle, but not in the Spin cycle. I did not try and run the Rinse cycle because I was afraid it wouldn't drain.
My dryer, Whirlpool Model #: WED5500SQ0, also started to squeak last night.
Not sure if they can be fixed, or if it's time to throw in the towel since they are 12 years old?!
fairbank56
#2 Posted : 11 years ago
fairbank56
Groups: Expert
Can't be more than 8 years old as those models came out in 2006. They are well worth fixing as opposed to buying the junk they sell nowadays. There may be something in the pump jamming it. I would pull the pump from the motor and see if washer will then spin. If motor still just hums, pull motor and set it on floor with wires still attached and try in spin mode again. If it still won't start in spin mode you may have a faulty timer.
Eric
Estate by Whirlpool Won't Spin, Just Buzzes (Washer Repair)
by Thundersloth 11 years ago
Whirlpool won't spin with clothes, agitates fine... (Washer Repair)
by billsooner 12 years ago
Whirlpool won't spin(knocking) (Washer Repair)
by cjenkins08 13 years ago
Whirlpool won't spin (Washer Repair)
by gloriacross 14 years ago
Whirlpool won't spin on gentle knit cycle (Washer Repair)
by Bowdaddy 14 years ago
Whirlpool Won't Spin (Washer Repair)
by hartzboys 14 years ago
Whirlpool won't spin, oil on ground. (Washer Repair)
by cartero 15 years ago
Belt drive Whirlpool won't spin (Washer Repair)
by brbartsc 16 years ago
by BillMuggelberg 17 years ago
by Satow 18 years ago
