Originally Posted by: eeigelberger  Thank you for the information. I was able to follow the steps and fix the "od" problem. Thanks again. eeigelberger, glad it worked out for you I have other issues I and others have worked on. You can find by placing in the search box dh1200s and locate those post. Good job on your LH lid lock fix...........Dick
Originally Posted by: dh1200s  eeigelberger, glad it worked out for you I have other issues I and others have worked on. You can find by placing in the search box dh1200s and locate those post.
Good job on your LH lid lock fix...........Dick Thank you LH lid lock is working. Do you have any suggestions for a timer that seems to reset during a washing cycle? My wife swears the timer will be counting down and then will go back up increasing the total cycle time before the washer completes a cycle. Needless to say she is not happy about that. Thanks, Ed.
Ed.
Is the issue failing during the rinse cycle or just as it's entering the rinse cycle. Your machine series may be what I call a 1st generation Outer Tub design.
When this issue starts stop the machine with the Off key pad (FAV6800A correct?) when the lid lock releases press the Spin Only key and let me know if the Spin Only cycle completes........Dick
