AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Cafe Series Dishwasher - Added Heat lights up and seems to run a cycle
I have a Cafe Series dishwasher and I'm hoping that fixing it will be cost effective, as it's probably the best dishwasher I've ever owned. I'm very handy and have a wide variety of tools, including electrician's tools. Here's the deal: The only button that will light-up is the "Added Heat" button (see attached); all others are dead and do not appear to do anything. If "Added Heat" is pressed once, it will fill with water and run a cycle. If pressed a second time, it will drain the dishwasher in what appears to be a "cancel" mode. Per the manual, I have reset the dishwasher by turning-off the power at the circuit breaker. This has not fixed the problem. I have not yet pulled the dishwasher or performed any ohms/voltage tests on anything. I was hoping for some tips before starting this project. Any and all advice will be appreciated. knuckbo attached the following image(s):
THIS FORUM IS DEAD!!!!!!! |
Thanks for the service manual. I test the keypad as well as the door switch. Keypad gave bad test results. I replaced keypad, but exact same issue. Any other suggestions? I hate to purchase a control board if that might not fix it.
Dishwasher Repair
