the last two loads of laundry resulted in fabrick getting caught in front of the drum and getting scorched on the edge there is a little play up and down on the drum when you look inside the drum does not apear to be centered is that due to a worn felt gasket or carrier rollers, can it be repaired and the best way to do it myself. Thanks Mike:confused:
The best way to diagnose this problem is to open up the dryer and see if you can determine what is causing the drum to be out of alignment.
Let us know what you find.
Good luck
